16:9 pal dv encoding problem
stewart charles
on Apr 21, 2009 at 4:15:53 pm
I’ve got a 6 min video shot in wide screen pal dv.
I’m making a DVD with just this video on. Im using apple compresser
I’m using the following settings
Encoder
MPEG2
Video format pal
Frame rate 25
16:9
Bottom first
2 pass vbr 5.5 7.2
Frame controls
Resize filter better (liner)
Output fields same as source
deinterlace fast liner averaging
Adaptive details checked
The problem is I have a clip with a small wind turbine which is spinning very fast. Aster encoding and authoring a DVD using DVD studio pro 4 this one clip looks bad, very bad. What am I doing wrong
http://www.thin-kingmedia.co.uk
Daniel Low
Re: 16:9 pal dv encoding problem
on Apr 21, 2009 at 6:42:01 pm
Why are you resizing and deinterlacing?
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
Michael Magallon
on Apr 23, 2009 at 1:46:40 am
As Daniel said, why deinterlace? More than likely, there is no interfield motion in your frames (i don't know what camera you shot with), which makes deinterlacing a moot point.
Anyway, to directly answer your specific question:
The field order is getting swapped.
Here is an updated summary of what you should do.
Encoder
MPEG2
Video format pal
Frame rate 25
16:9
Bottom first (CHANGE TO TOP FIELD FIRST)
2 pass vbr 5.5 7.2 (CHANGE AVERAGE TO 6.4 Mbps, MAXIMUM TO 7.5 Mbps)
Frame controls (ALL FRAME CONTROLS OFF)
Let us know if this helps.
MM
Daniel Low
on Apr 23, 2009 at 6:55:45 pm
[Michael Magallon] "Bottom first (CHANGE TO TOP FIELD FIRST)"
Ignore this. PAL DV is Lower (Bottom) field first
Turn of deinterlacing
Michael Magallon
on Apr 23, 2009 at 9:09:12 pm
MPEG2 PAL field dominance is TFF.
He is creating an MPEG2 file, not a PAL DV file.
"The problem is I have a clip with a small wind turbine which is spinning very fast. Aster encoding and authoring a DVD using DVD studio pro 4 this one clip looks bad, very bad. What am I doing wrong "
However, the above comment is a little vague, so I will wait on responding further until he gives us more details. Does it look bad on a CRT, LCD, plasma or your computer monitor? Is the motion jittery on pans or is the overall quality not acceptable to your standards?
But please show a little courtesy Daniel Low, as I do to everyone on this board.
MM
Daniel Low
on Apr 23, 2009 at 9:53:36 pm
[Michael Magallon] "MPEG2 PAL field dominance is TFF."
With all due respect, you are wrong, for DVD it's LFF.
There are of course MPEG-2 based PAL broadcast formats that are TFF and I assume that is why you are confused.
If you or the OP are uncertain it's best to set this to 'Automatic' in compressor.
More info from the experts here:
http://www.doom9.org/index.html?/dv/guide.html
stewart charles
on Apr 24, 2009 at 8:47:11 am
Sorry for the lack of details.
I have filmed a 6 min video its been shot on a sony z1e the camera was set to down convert and I captured the footage as 16:9 dv pal.
The footage has been edited using fcp on a Mac book pro. I exported a self contained QuickTime movie.
I used the settings I posted and on my Mac book pro it looked ok, on lcd monitors it looks ok but this one clip looks really bad on normal TVs (crt).
I am now just about to try all the suggestions in this post.
I will post later with the results.
Thanks again for all info.
stewart charles
on Apr 24, 2009 at 8:41:06 am
I will also try this!
stewart charles
on Apr 24, 2009 at 9:45:13 am
Daniel
Just trying out what you suggested.
How do I turn off the deinterlace if I have frame controls off?)
stewart charles
on Apr 24, 2009 at 9:49:53 am
Daniel
stewart charles
on Apr 24, 2009 at 8:39:47 am
hello
sorry for the late reply. thanks for the info I will try this.
and let you no how I get on.
stewart charles
on Apr 24, 2009 at 9:41:23 am
michael
I’ve just tried what you suggested, it looks ok on lcd monitors but the whole thing looks really really bad when played on a TV (crt)
Im gussing its me?
