Important Compression Question
Dan Newton
on Apr 11, 2009 at 6:17:31 pm
I have three questions ---
i have the following programs ----
SQUEEZE and COMPRESSOR
I want to do the following
how do you convert a MOV to FLV
how do you convert a MOV MPEG 2
how do you convert a MOV to AVI
Could someone please write out a step by step on how to do each one its extremely important
Daniel Low
Re: Important Compression Question
on Apr 11, 2009 at 7:51:04 pm
Use the supplied presets in either program and applied them to your imported MOVs, it couldn't be simpler!
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
Dan Newton
on Apr 12, 2009 at 6:18:15 am
hey there
but there is nop option to convert to AVI on either
Daniel Low
on Apr 12, 2009 at 10:07:31 am
What kind of AVI to you want to create?
Dan Newton
on Apr 12, 2009 at 10:27:12 am
well the MOV is
720 x 576
25 frames
so i want to make the AVI similar
Daniel Low
on Apr 12, 2009 at 10:33:21 am
Yes but AVI is a format, not a codec, what AVI codec do you need to export to?
Dan Newton
on Apr 12, 2009 at 10:40:47 am
Hey
Sorry I'm new to this conversion thing to avi --- can you explain the type of codecs they have ---
which one do you recommend
Daniel Low
on Apr 12, 2009 at 10:44:23 am
What are the AVIs going to be used for?
Dan Newton
on Apr 12, 2009 at 11:00:46 am
well one of three things
for personal viewing like a high res mpeg
Daniel Low
on Apr 12, 2009 at 1:01:24 pm
I try and avoid AVI unless it's DV AVI.
Have a go with this:
http://www.divx.com/en/products/software/mac/divx
It's the most popular AVI codec.
