Apple Compressor--Stereo is not Stereo
David Rowan
on Mar 11, 2009 at 11:28:50 pm
I need to convert my finished edit to an MPEG file, with embedded audio.
I use the "MPEG 2-->Program Stream" setting.
I am happy with the results, except:
Its taking the two stereo tracks that I export and mixing them together. The new file has stereo audio, but its just a mix of what was originally two independant tracks.
I cannot find anywhere in the inspector a place to make sure that the audio gets seperated properly. Where do I look?
Compressor 3.0.5 on MacPro dual quad core. OS 10.5.6. The original files are Standard Def IMX files, I export them from the timeline with some tracks panned left and some panned right, and they are, indeed, stereo.
Daniel Low
Re: Apple Compressor--Stereo is not Stereo
on Mar 12, 2009 at 7:49:23 am
[David Rowan] "The new file has stereo audio, but its just a mix of what was originally two independant tracks. "
Check with the manual - that's what's supposed to happen.
Fonts are like cologne:
A bad choice speaks louder than a good one.
