droplets wont import to compressor
lars cuzner
on Mar 10, 2009 at 9:18:06 pm
Can someone here tell me how to import exterior droplets in to Compressor?
Daniel Low
Re: droplets wont import to compressor
on Mar 10, 2009 at 11:01:06 pm
As far as I know you can't. Droplets are specific to your machine, cluster, network etc.
If you want settings from somebody else, get them to send you a compressor setting and create a Droplet from there
Fonts are like cologne:
A bad choice speaks louder than a good one.
lars cuzner
on Mar 10, 2009 at 11:17:41 pm
Ok, thanks Daniel. In that case, would all the necessary settings be visable in the droplet?
And While I have you here...
The compression I am doing is from PAL assets, the droplets are done by someone who is in NTSC. Should this matter? I mean, I am compressing for web, it shouldn't matter right?
Daniel Low
on Mar 10, 2009 at 11:55:33 pm
[lars cuzner] "In that case, would all the necessary settings be visable in the droplet? "
Yes, if you can open and interpret them.
[lars cuzner] "The compression I am doing is from PAL assets, the droplets are done by someone who is in NTSC. Should this matter? I mean, I am compressing for web, it shouldn't matter right? "
Yes it does matter, PAL and NTSC have different frame sizes and frame rates, you want to compress PAL to 25fps not 30fps, etc, keyframes and GOPs change too.
lars cuzner
on Mar 11, 2009 at 2:57:05 pm
Hey Daniel, how would you feel about me emailing you that droplet and you telling me what is messed up from a PAL perspective? My email is lars@larscuzner.com
Doesn't seem to me that it carries enough information, but what do I know.
Art films. I do all filming and post. Using Sony EX 1 and FCP 6.
Daniel Low
on Mar 13, 2009 at 11:36:14 am
To look inside a droplet, right click on it > Show Package Contents and find the Settings folder in Resources. In there drag your settings file onto TextEdit.
If you could copy and paste that here that would be great.
lars cuzner
on Mar 13, 2009 at 4:05:22 pm
Here is one that is giving me some choppiness right now.
From droplet:
Do%2520not%2520use%2520on%2520aspects%2520other%2520than%2520specified%2520-%2520will%2520cause%2520picture%2520distortion.%2520Mimics%2520Apple%2520Trailer.%2520default-destinationmovyesyes01 2 3 0 Y 0 1 1 2-100avc11167360001no
lars cuzner
on Mar 13, 2009 at 4:39:50 pm
well, that didn't work,
Try this
or other suggestions?
default-destinationmovyesyes x5hdWRpAAAAAQAAAAcAAAAAAAAAPG9zYmQAAAABAAAAAAAAAABA5YiAAAAAAGFhYyAAAAAAAAAAAAAABAAAAAAAAAAAAgAAAAAAAAAAAAAAHGF
pc3IAAAABAAAAAAAAAABBF3AAAAAAAAAAGkljZHN0AAAAAQAAAAAAAAAAPD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPCFET0NUWVBFIHB
saXN0IFBVQkxJQyAiLS8vQXBwbGUvL0RURCBQTElTVCAxLjAvL0VOIiAiaHR0cDovL3d3dy5hcHBsZS5jb20vRFREcy9Qcm9wZXJ0eUxpc3QtMS4wLmR0ZCI
+CjxwbGlzdCB2ZXJzaW9uPSIxLjAiPgo8YXJyYXk+Cgk8ZGljdD4KCQk8a2V5PmNvbnZlcnRlcjwva2V5PgoJCTxzdHJpbmc+U2FtcGxlUmF0ZUNvbnZlcnRlcjwvc
3RyaW5nPgoJCTxrZXk+bmFtZTwva2V5PgoJCTxzdHJpbmc+U2FtcGxlIFJhdGUgQ29udmVydGVyPC9zdHJpbmc+CgkJPGtleT5wYXJhbWV0ZXJzPC9rZXk+CgkJPGFycm
F5PgoJCQk8ZGljdD4KCQkJCTxrZXk+YXZhaWxhYmxlIHZhbHVlczwva2V5PgoJCQkJPGFycmF5PgoJCQkJCTxzdHJpbmc+RmFzdGVyPC9zdHJpbmc+CgkJCQkJPHN0cm
luZz5GYXN0PC9zdHJpbmc+CgkJCQkJPHN0cmluZz5Ob3JtYWw8L3N0cmluZz4KCQkJCQk8c3RyaW5nPkJldHRlcjwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QmVzdDwvc
3RyaW5nPgoJCQkJPC9hcnJheT4KCQkJCTxrZXk+Y3VycmVudCB2YWx1ZTwva2V5PgoJCQkJPGludGVnZXI+MjwvaW50ZWdlcj4KCQkJCTxrZXk+aGludDwva2V5Pgo
JCQkJPGludGVnZXI+MDwvaW50ZWdlcj4KCQkJCTxrZXk+a2V5PC9rZXk+CgkJCQk8c3RyaW5nPlF1YWxpdHk8L3N0cmluZz4KCQkJCTxrZXk+bmFtZTwva2V5PgoJCQk
JPHN0cmluZz5RdWFsaXR5PC9zdHJpbmc+CgkJCQk8a2V5PnN1bW1hcnk8L2tleT4KCQkJCTxzdHJpbmc+UXVhbGl0eSBzZXR0aW5nIGZvciB0aGUgc2FtcGxlIHJhdGUg
Y29udmVydGVyLjwvc3RyaW5nPgoJCQkJPGtleT52YWx1ZSB0eXBlPC9rZXk+CgkJCQk8aW50ZWdlcj4yMjwvaW50ZWdlcj4KCQkJPC9kaWN0PgoJCQk8ZGljdD4KCQkJCT
xrZXk+YXZhaWxhYmxlIHZhbHVlczwva2V5PgoJCQkJPGFycmF5PgoJCQkJCTxzdHJpbmc+UHJlPC9zdHJpbmc+CgkJCQkJPHN0cmluZz5Ob3JtYWw8L3N0cmluZz4KCQkJCQ
k8c3RyaW5nPk5vbmU8L3N0cmluZz4KCQkJCTwvYXJyYXk+CgkJCQk8a2V5PmN1cnJlbnQgdmFsdWU8L2tleT4KCQkJCTxpbnRlZ2VyPjE8L2ludGVnZXI+CgkJCQk8a2V5P
mhpbnQ8L2tleT4KCQkJCTxpbnRlZ2VyPjI8L2ludGVnZXI+CgkJCQk8a2V5PmtleTwva2V5PgoJCQkJPHN0cmluZz5QcmltaW5nIE1ldGhvZDwvc3RyaW5nPgoJCQkJPG
tleT5uYW1lPC9rZXk+CgkJCQk8c3RyaW5nPlByaW1pbmcgTWV0aG9kPC9zdHJpbmc+CgkJCQk8a2V5PnN1bW1hcnk8L2tleT4KCQkJCTxzdHJpbmc+UHJpbWluZyBtZXRob
2QgZm9yIHRoZSBzYW1wbGUgcmF0ZSBjb252ZXJ0ZXIuPC9zdHJpbmc+CgkJCQk8a2V5PnZhbHVlIHR5cGU8L2tleT4KCQkJCTxpbnRlZ2VyPjIyPC9pbnRlZ2VyPgoJCQk
8L2RpY3Q+CgkJPC9hcnJheT4KCQk8a2V5PnZlcnNpb248L2tleT4KCQk8aW50ZWdlcj4wPC9pbnRlZ2VyPgoJPC9kaWN0PgoJPGRpY3Q+CgkJPGtleT5jb252ZXJ0ZXI8L2
tleT4KCQk8c3RyaW5nPkNvZGVjQ29udmVydGVyPC9zdHJpbmc+CgkJPGtleT5uYW1lPC9rZXk+CgkJPHN0cmluZz5NUEVHIDQgQUFDIExDIEVuY29kZXI8L3N0cmluZz
4KCQk8a2V5PnBhcmFtZXRlcnM8L2tleT4KCQk8YXJyYXk+CgkJCTxkaWN0PgoJCQkJPGtleT5FeHBsaWNpdFZhbHVlPC9rZXk+CgkJCQk8aW50ZWdlcj42NjE5MTM4PC9
pbnRlZ2VyPgoJCQkJPGtleT5hdmFpbGFibGUgdmFsdWVzPC9rZXk+CgkJCQk8YXJyYXk+CgkJCQkJPHN0cmluZz5Nb25vPC9zdHJpbmc+CgkJCQkJPHN0cmluZz
5TdGVyZW88L3N0cmluZz4KCQkJCQk8c3RyaW5nPlF1YWRyYXBob25pYzwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QUFDIDQuMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+
QUFDIDUuMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QUFDIDUuMTwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QUFDIDYuMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QUFDIDY
uMTwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QUFDIDcuMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+QUFDIDcuMTwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+T2N0YWdvbmFsPC9
zdHJpbmc+CgkJCQk8L2FycmF5PgoJCQkJPGtleT5jdXJyZW50IHZhbHVlPC9rZXk+CgkJCQk8aW50ZWdlcj4xPC9pbnRlZ2VyPgoJCQkJPGtleT5oaW50PC9rZXk+
CgkJCQk8aW50ZWdlcj41PC9pbnRlZ2VyPgoJCQkJPGtleT5rZXk8L2tleT4KCQkJCTxzdHJpbmc+Q2hhbm5lbCBDb25maWd1cmF0aW9uPC9zdHJpbmc+CgkJCQk8a
2V5PmxpbWl0ZWQgdmFsdWVzPC9rZXk+CgkJCQk8YXJyYXk+CgkJCQkJPHN0cmluZz5TdGVyZW88L3N0cmluZz4KCQkJCTwvYXJyYXk+CgkJCQk8a2V5Pm5hbWU8L2tle
T4KCQkJCTxzdHJpbmc+Q2hhbm5lbCBDb25maWd1cmF0aW9uPC9zdHJpbmc+CgkJCQk8a2V5PnN1bW1hcnk8L2tleT4KCQkJCTxzdHJpbmc+VGhlIGNoYW5uZWwgbGF5b3V0IG9
mIHRoZSBBQUMgcHJvZHVjZWQgYnkgdGhlIGVuY29kZXI8L3N0cmluZz4KCQkJCTxrZXk+dmFsdWUgdHlwZTwva2V5PgoJCQkJPGludGVnZXI+MjI8L2ludGVnZXI+CgkJCTwv
ZGljdD4KCQkJPGRpY3Q+CgkJCQk8a2V5PkV4cGxpY2l0VmFsdWU8L2tleT4KCQkJCTxyZWFsPjQ0MTAwPC9yZWFsPgoJCQkJPGtleT5hdmFpbGFibGUgdmFsdWVzPC9rZXk+
CgkJCQk8YXJyYXk+CgkJCQkJPHN0cmluZz5SZWNvbW1lbmRlZDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+OC4wMDA8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjExLjAyNTwvc
3RyaW5nPgoJCQkJCTxzdHJpbmc+MTIuMDAwPC9zdHJpbmc+CgkJCQkJPHN0cmluZz4xNi4wMDA8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjIyLjA1MDwvc3RyaW5nPgoJCQk
JCTxzdHJpbmc+MjQuMDAwPC9zdHJpbmc+CgkJCQkJPHN0cmluZz4zMi4wMDA8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjQ0LjEwMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+
NDguMDAwPC9zdHJpbmc+CgkJCQk8L2FycmF5PgoJCQkJPGtleT5jdXJyZW50IHZhbHVlPC9rZXk+CgkJCQk8aW50ZWdlcj44PC9pbnRlZ2VyPgoJCQkJPGtleT5oaW50PC9
rZXk+CgkJCQk8aW50ZWdlcj42PC9pbnRlZ2VyPgoJCQkJPGtleT5rZXk8L2tleT4KCQkJCTxzdHJpbmc+U2FtcGxlIFJhdGU8L3N0cmluZz4KCQkJCTxrZXk+bGlta
XRlZCB2YWx1ZXM8L2tleT4KCQkJCTxhcnJheT4KCQkJCQk8c3RyaW5nPlJlY29tbWVuZGVkPC9zdHJpbmc+CgkJCQkJPHN0cmluZz4yMi4wNTA8L3N0cmluZz4KCQk
JCQk8c3RyaW5nPjI0LjAwMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+MzIuMDAwPC9zdHJpbmc+CgkJCQkJPHN0cmluZz40NC4xMDA8L3N0cmluZz4KCQkJCQk8c3Rya
W5nPjQ4LjAwMDwvc3RyaW5nPgoJCQkJPC9hcnJheT4KCQkJCTxrZXk+bmFtZTwva2V5PgoJCQkJPHN0cmluZz5TYW1wbGUgUmF0ZTwvc3RyaW5nPgoJCQkJPGtleT5zd
W1tYXJ5PC9rZXk+CgkJCQk8c3RyaW5nPlRoZSBzYW1wbGUgcmF0ZSBvZiB0aGUgQUFDIHByb2R1Y2VkIGJ5IHRoZSBlbmNvZGVyPC9zdHJpbmc+CgkJCQk8a2V5PnVua
XQ8L2tleT4KCQkJCTxzdHJpbmc+a0h6PC9zdHJpbmc+CgkJCQk8a2V5PnZhbHVlIHR5cGU8L2tleT4KCQkJCTxpbnRlZ2VyPjIyPC9pbnRlZ2VyPgoJCQk8L2RpY3Q+
CgkJCTxkaWN0PgoJCQkJPGtleT5FeHBsaWNpdFZhbHVlPC9rZXk+CgkJCQk8aW50ZWdlcj4wPC9pbnRlZ2VyPgoJCQkJPGtleT5hdmFpbGFibGUgdmFsdWVzPC9rZXk+
CgkJCQk8YXJyYXk+CgkJCQkJPHN0cmluZz5BdmVyYWdlIEJpdCBSYXRlPC9zdHJpbmc+CgkJCQkJPHN0cmluZz5WYXJpYWJsZSBCaXQgUmF0ZTwvc3RyaW5nPgoJCQkJCT
xzdHJpbmc+VmFyaWFibGUgQml0IFJhdGUgQ29uc3RyYWluZWQ8L3N0cmluZz4KCQkJCQk8c3RyaW5nPkNvbnN0YW50IEJpdCBSYXRlPC9zdHJpbmc+CgkJCQk8L2Fycm
F5PgoJCQkJPGtleT5jdXJyZW50IHZhbHVlPC9rZXk+CgkJCQk8aW50ZWdlcj4zPC9pbnRlZ2VyPgoJCQkJPGtleT5oaW50PC9rZXk+CgkJCQk8aW50ZWdlcj41PC9pbn
RlZ2VyPgoJCQkJPGtleT5rZXk8L2tleT4KCQkJCTxzdHJpbmc+VGFyZ2V0IEZvcm1hdDwvc3RyaW5nPgoJCQkJPGtleT5saW1pdGVkIHZhbHVlczwva2V5PgoJCQkJPGF
ycmF5PgoJCQkJCTxzdHJpbmc+QXZlcmFnZSBCaXQgUmF0ZTwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+VmFyaWFibGUgQml0IFJhdGU8L3N0cmluZz4KCQkJCQk8c3RyaW5n
PlZhcmlhYmxlIEJpdCBSYXRlIENvbnN0cmFpbmVkPC9zdHJpbmc+CgkJCQkJPHN0cmluZz5Db25zdGFudCBCaXQgUmF0ZTwvc3RyaW5nPgoJCQkJPC9hcnJheT4KCQkJCT
xrZXk+bmFtZTwva2V5PgoJCQkJPHN0cmluZz5FbmNvZGluZyBTdHJhdGVneTwvc3RyaW5nPgoJCQkJPGtleT5zdW1tYXJ5PC9rZXk+CgkJCQk8c3RyaW5nPlRoZSBlbmNv
ZGluZyBzdHJhdGVneSB1c2VkIGZvciB0aGUgYml0IGFsbG9jYXRpb248L3N0cmluZz4KCQkJCTxrZXk+dmFsdWUgdHlwZTwva2V5PgoJCQkJPGludGVnZXI+MjI8L2lud
GVnZXI+CgkJCTwvZGljdD4KCQkJPGRpY3Q+CgkJCQk8a2V5PkJpdFJhdGVPZmZzZXQ8L2tleT4KCQkJCTxpbnRlZ2VyPjI8L2ludGVnZXI+CgkJCQk8a2V5PkV4cGxpY2l0V
mFsdWU8L2tleT4KCQkJCTxpbnRlZ2VyPjExMjAwMDwvaW50ZWdlcj4KCQkJCTxrZXk+YXZhaWxhYmxlIHZhbHVlczwva2V5PgoJCQkJPGFycmF5PgoJCQkJCTxzdHJpbmc+
UmVjb21tZW5kZWQ8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjE2PC9zdHJpbmc+CgkJCQkJPHN0cmluZz4yMDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+MjQ8L3N0cmluZz4KCQ
kJCQk8c3RyaW5nPjI4PC9zdHJpbmc+CgkJCQkJPHN0cmluZz4zMjwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+NDA8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjQ4PC9zdHJpbmc+
CgkJCQkJPHN0cmluZz41Njwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+NjQ8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjcyPC9zdHJpbmc+CgkJCQkJPHN0cmluZz44MDwvc3RyaW5
nPgoJCQkJCTxzdHJpbmc+OTY8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjExMjwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+MTI4PC9zdHJpbmc+CgkJCQkJPHN0cmluZz4xNDQ8L3N0
cmluZz4KCQkJCQk8c3RyaW5nPjE2MDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+MTkyPC9zdHJpbmc+CgkJCQkJPHN0cmluZz4yMjQ8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjI1N
jwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+Mjg4PC9zdHJpbmc+CgkJCQkJPHN0cmluZz4zMjA8L3N0cmluZz4KCQkJCTwvYXJyYXk+CgkJCQk8a2V5PmN1cnJlbnQgdmFsdWU8L2
tleT4KCQkJCTxpbnRlZ2VyPjEzPC9pbnRlZ2VyPgoJCQkJPGtleT5oaW50PC9rZXk+CgkJCQk8aW50ZWdlcj40PC9pbnRlZ2VyPgoJCQkJPGtleT5rZXk8L2tleT4KCQkJCT
xzdHJpbmc+Qml0IFJhdGU8L3N0cmluZz4KCQkJCTxrZXk+bGltaXRlZCB2YWx1ZXM8L2tleT4KCQkJCTxhcnJheT4KCQkJCQk8c3RyaW5nPlJlY29tbWVuZGVkPC9zdHJpbmc
+CgkJCQkJPHN0cmluZz42NDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+NzI8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjgwPC9zdHJpbmc+CgkJCQkJPHN0cmluZz45Njwvc3Rya
W5nPgoJCQkJCTxzdHJpbmc+MTEyPC9zdHJpbmc+CgkJCQkJPHN0cmluZz4xMjg8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjE0NDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+MTY
wPC9zdHJpbmc+CgkJCQkJPHN0cmluZz4xOTI8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjIyNDwvc3RyaW5nPgoJCQkJCTxzdHJpbmc+MjU2PC9zdHJpbmc+CgkJCQkJPHN0
cmluZz4yODg8L3N0cmluZz4KCQkJCQk8c3RyaW5nPjMyMDwvc3RyaW5nPgoJCQkJPC9hcnJheT4KCQkJCTxrZXk+bmFtZTwva2V5PgoJCQkJPHN0cmluZz5UYXJnZXQg
Qml0IFJhdGU8L3N0cmluZz4KCQkJCTxrZXk+c3VtbWFyeTwva2V5PgoJCQkJPHN0cmluZz5FbmNvZGluZyBmb3IgdHJhbnNtaXNzaW9uIHdpdGggYSBjb25zdGFudCBia
XQgcmF0ZTwvc3RyaW5nPgoJCQkJPGtleT51bml0PC9rZXk+CgkJCQk8c3RyaW5nPmticHM8L3N0cmluZz4KCQkJCTxrZXk+dmFsdWUgdHlwZTwva2V5PgoJCQkJPGludGVn
ZXI+MjI8L2ludGVnZXI+CgkJCTwvZGljdD4KCQkJPGRpY3Q+CgkJCQk8a2V5PkV4cGxpY2l0VmFsdWU8L2tleT4KCQkJCTxpbnRlZ2VyPjY0PC9pbnRlZ2VyPgoJCQkJPGtl
eT5hdmFpbGFibGUgdmFsdWVzPC9rZXk+CgkJCQk8YXJyYXk+CgkJCQkJPHN0cmluZz5Hb29kPC9zdHJpbmc+CgkJCQkJPHN0cmluZz5CZXR0ZXI8L3N0cmluZz4KCQkJCQk8c
3RyaW5nPkJlc3Q8L3N0cmluZz4KCQkJCTwvYXJyYXk+CgkJCQk8a2V5PmN1cnJlbnQgdmFsdWU8L2tleT4KCQkJCTxpbnRlZ2VyPjE8L2ludGVnZXI+CgkJCQk8a2V5Pmhpbn
Q8L2tleT4KCQkJCTxpbnRlZ2VyPjE8L2ludGVnZXI+CgkJCQk8a2V5PmtleTwva2V5PgoJCQkJPHN0cmluZz5RdWFsaXR5PC9zdHJpbmc+CgkJCQk8a2V5Pm5hbWU8L2tleT4KCQ
kJCTxzdHJpbmc+UXVhbGl0eTwvc3RyaW5nPgoJCQkJPGtleT5zdW1tYXJ5PC9rZXk+CgkJCQk8c3RyaW5nPlRoZSBxdWFsaXR5IG9mIHRoZSBlbmNvZGVkIEFBQyBiaXRzd
HJlYW08L3N0cmluZz4KCQkJCTxrZXk+dmFsdWUgdHlwZTwva2V5PgoJCQkJPGludGVnZXI+MjI8L2ludGVnZXI+CgkJCTwvZGljdD4KCQk8L2FycmF5PgoJCTxrZXk+dmVyc
2lvbjwva2V5PgoJCTxpbnRlZ2VyPjE8L2ludGVnZXI+Cgk8L2RpY3Q+CjwvYXJyYXk+CjwvcGxpc3Q+CgAAACBjbGF5AAAAAQAAAAAAAAAAAGUAAgAAAAAAAAAAAAAAFXJ
lY28AAAABAAAAAAAAAAAAAAAAGHFsdHkAAAABAAAAAAAAAAAAAAB/AAAAHHZlcnMAAAABAAAAAAAAAAAAAwAVAAEAAAAAABhzc2N0AAAAAQAAAAAAAAAAbXA0YQAAABhzc
3J0AAAAAQAAAAAAAAAArEQAAAAAABZzc3NzAAAAAQAAAAAAAAAAABAAAAAWc3NjYwAAAAEAAAAAAAAAAAACAAAAZ2NkZWMAAAABAAAAAAAAAAAAAAAMZnJtYW1wNGEAAAAMb
XA0YQAAAAAAAAAzZXNkcwAAAAADgICAIgAAAASAgIAUQBUAGAAAAbWAAAG1gAWAgIACEhAGgICAAQIAAAAIAAAAAAAAABx2ZXJzAAAAAQAAAAAAAAAAAAMAFAABAAA=]]>
Daniel Low
on Mar 13, 2009 at 7:19:57 pm
That setting appears to be for AVC (H.264) at 1920x1080 - not PAL.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
