DV to IMX30 Capture with firewire gives bad quality
Luuk Meijer
on Mar 3, 2009 at 10:54:48 am
Hello,
I have a strange problem when I capture dvcam with a firewire device and I convert it directly to IMX30.
The edges seem to be verry jaggy after the conversion.
And the thing was that it wasn't this way before. It started a couple of weeks before.
I tested it on several systems, MacPro/Imac/Macbookpro/G5 all same problem.
I use final cut pro, and a dvcam deck or camera (same problem)
The conversion goes good when I Capture via AJA Kona (component or SDI)
excelent quality!
I am now forced to capture first to DV and than convert it on my mac to IMX.
can this be a quicktime related problem? And does anyone else has the same issues, hopefully with a solution?
Thanx!
