Problems converting my .MOV file
Alex Sava
on Mar 1, 2009 at 3:24:35 pm
Hello. I have a slight problem converting my mov files to mpeg4 or mpeg2 for dvd. My raw files were .mov, which I've edited with After Effects and Premiere and used Quicktime PNG all the time. Now, everything is fine, but my 12 minute clip is a few gigs in size, so whenever I convert it to something else, I get the same problem. The quality is okay, but the image has less contrast, and has a "washed out" look.
Here's an example : http://img8.imageshack.us/my.php?image=creativecow.jpg
On top is a screenshot of my .mov, the one on the bottom is an mpeg4. And I get that with anything I convert it to. I use Adobe Media Encoder btw, and I've played around with the settings and nothing changes.
I am aware you lose quality when converting from 5 gigs to 300-400 mb, but colors should remain the same.
The weird thing is, when uploading the mpeg4 to vimeo, the contrast is back again, like nothing happened.
Any suggestions?
Chris Blair
Re: Problems converting my .MOV file
on Mar 1, 2009 at 4:50:32 pm
There's an earlier post from just a couple of days ago about this issue. It has to do with gamma/color shifts caused by a bug in Quicktime. There are some workarounds. Read through the posts from the last 2 or 3 days and you should find them.
http://forums.creativecow.net/readpost/20/861730
http://forums.creativecow.net/readpost/20/861731
The easiest one we've found is to NOT use quicktime as the container for the H264 file. So if you have access to an encoder that will simply export an H264/MP4 file, the issue is greatly minimized. Also using an atlternative H264 codec from the one supplied with Quicktime is supposed to fix it, but I haven't personally tried it.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
