5th compression n still lost with sorenson 5
Jason Barczewski
on Feb 18, 2009 at 4:20:24 pm
I'm trying to figure out sorenson and I've been just playing with a 4 min clip that I want to look great and sound great in flash.
After a couple hours of different compressions, I'm still at square 1.
new to sorenson, just figuring out the presets as I go.
using on2 vp6 pro, hope that is good
can anyone give me help on the settings.
best I got was f8 1mb
video 640 x 360
1000 kbps
2 pass vbr
it's a 4 min film in widescreen 16:9
It's still very pixelated
Help
Daniel Low
Re: 5th compression n still lost with sorenson 5
on Feb 18, 2009 at 7:46:14 pm
More info please:
What's your source format?
What is your source content?
What does "best I got was f8 1mb" mean?
Fonts are like cologne:
A bad choice speaks louder than a good one.
Jason Barczewski
on Feb 18, 2009 at 7:58:03 pm
source format is quicktime movie format .mov
not sure what souce content means, but the video is made for instructional purposes with intro and exit graphics with audio
video is being used to teach content in a person to person style (interview) indoors
f8 1mb is a sorenson squeeze 5 preset but that video is still pixelated.
Daniel Low
on Feb 18, 2009 at 10:40:05 pm
Quicktime .mov is just a wrapper, I need to know the codec used. Open the movie in quicktime player and go to the Window menu, 'Show Movie inspector'
Make a note of all what is says there and let me know.
By content I mean is it 'Talking heads', 'Graphics/Animation', 'Action', 'Text Presentation' etc.....What is the footage of?
Jason Barczewski
on Feb 18, 2009 at 11:02:42 pm
here is the info you asked for in the attachments.
10 second intro and 10 second exit have graphics (shown in pic) graphics then it's basically an interview with on screen talent
thanks
Daniel Low
on Feb 18, 2009 at 11:25:06 pm
Ok, the frame size of your source is 4:3 (It's a DV Frame size), is the onscreen talent stuff shot widescreen?
The problem is probably that you've got square pixel graphics mixed up with non-square pixel DV material all exported to PhotoJPEG which is square pixel.
Do the people in the video look normally shaped?
If it's not widescreen then try resizing the clip to 640x480 when you encode it, if its still pixelated or blocky, try 480x360.
Jason Barczewski
on Feb 18, 2009 at 11:31:35 pm
yeah the talent is shot in widescreen 16:9 I'm trying to correct that now
I rendered it again using mpeg4 and ACC for audio and the 4 min video was 147 mb which is a bit big as this will be used on a blog and then mass distibuted to video/youtube sharing sites.
Daniel Low
on Feb 18, 2009 at 11:43:04 pm
Stick with Flash for now
Did you apply a deinterlace filter in Squeeze, if not you need to
Try a frame size of 512x288
Jason Barczewski
on Feb 19, 2009 at 12:01:13 am
I don't think I applied it using squeeze 5. I can redo the original deinterlaced.
I'll stick with your advice for flash, can I ask why? Is it a more broadly used format or easier for me being the newb that I am?
I just rendered an h264/AAC which is the best so far, and only 23.69mb
data rate 792 kbps
fps 14.98
848x480 pixel
I'll try what you mentioned with the deinterlace
Daniel Low
on Feb 19, 2009 at 12:18:51 am
There are more Flash 8 (VP6) enabled computers out there than Flash 9 (H.264). Standard MPEG-4 is not as high quality as VP6. Confusing as H.264 can also be MP4.
It's very late here - look them up on Wiki... ;-)
