Compressing 1TB of media to work from home/back up
Christian Hart
on Feb 10, 2009 at 8:20:43 pm
Hullo there
i'd like to compress about 1.6TB of DVCProHD rushes to something far less chunky
so that I can work from home on the laptop if needs be then bring that project
back into work with me and re-link it to the DVCProHD rushes.
Also - if the main mac pro has down time for any reason i can keep working till
it's back up. Time's super tight on this one....
I'm thinking there are 2 basic ways for me to do this - Media Manager or Compressor.
Which do you think would be the best way forward? I was thinking maybe a couple of
nights transcoding might do the trick... Am i way out?
I don't need super high quality - just something rough and ready with low file sizes - maybe
so i can edit from my little 232GB FW400 portable drive. Is that possible??
If not a G-raid is an option if going that small would take for ever.
Firstly - Is this just a dumb idea?
Secondly - Can anyone suggest a good compression codec/data rate to set it to
given the above? Currently it's all DVCProHD 25fps and i don't know quite where to
start - trancoding to standard PAL would only cut it down to about 35% of it's original size.
Oh - i'm using FCP 6.04 OSX 10.4.11 etc on a 4 x 2,5 G5
thanks muchly!
Daniel Low
Re: Compressing 1TB of media to work from home/back up
on Feb 11, 2009 at 10:43:30 am
This is more of a workflow thing, I'd suggest the guys in the FCP forum would be better qualified to answer.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Christian Hart
on Feb 11, 2009 at 11:39:52 am
Ok - will do - sorry!
Daniel Low
on Feb 11, 2009 at 12:16:19 pm
No worries.
It would be easy to tell you how to compress your video down to a small size but in turn that may introduce a nightmare moving back and forth between FCPs.
