exporting video files
james laan
on Jan 29, 2009 at 4:21:59 am
i am trying to take clips from fcp6 and export them. then take the exported files and convert them into a viewable format. then burn the converted files on to a disc just as files to be viewed on a windows pc. my question would be, what is the best format to convert them to after i export them from final cut to maintain quality and to be viewed on a pc?
Daniel Low
Re: exporting video files
on Jan 29, 2009 at 7:39:01 am
PCs and Macs aren't that different, there are a bunch of different formats you could use. Is there something 'special' or lacking with the PC you are targeting?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
james laan
on Jan 29, 2009 at 3:20:17 pm
no nothing special. its for a friends pc and i dont know what format i should export in so he can view the files with no issues. but theres nothing wrong or special about his pc
Daniel Low
on Jan 29, 2009 at 4:38:07 pm
If he has Quicktime installed (which he should if he cares at all about video) then use one of the Quicktime codecs like PhotoJPEG or H.264 or MPEG-4
If you want full screen and high quality give give him MPEG-2.
Otherwise you'll be getting into the complicated world or Divx AVIs or WMVs
james laan
on Jan 30, 2009 at 2:10:15 am
can i export in mpeg-2 from fcp6?
Daniel Low
on Jan 30, 2009 at 7:52:36 am
No, you'd use compressor.
james laan
on Jan 31, 2009 at 12:21:11 am
hey thanks alot. i really appreciate your help
ill try that then respond back
thanks again
