Best Compression for Presentation
Sam Waldorf
on Jan 17, 2009 at 6:05:03 pm
My organization is preparing a presentation of about a dozen films.
5 of which are in High Definition, the rest are in standard definition.
We are going to compress all the quicktime files (in Apple's Compressor) to MPEG-2 to be put on a dvd that will then be upscaled in a blu-ray player.
Most of the projects are about 5 min. in length.
The HD projects are about 10-12 min. in length.
What are the best compression settings for this? Best bitrate etc?
Daniel Low
Re: Best Compression for Presentation
on Jan 18, 2009 at 9:15:34 pm
Start with compressors 60 or 90 minute preset and tweak it from there.
From here, it's impossible for me to give you any more detailed advice without seeing a sample of the footage you are dealing with.
Downscale either the HD projects in either FCP or compressor depending on what you are more comfortable with but search this and other forums for tips.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Sam Waldorf
on Jan 18, 2009 at 10:13:23 pm
Thanks for the tip, that was the plan anyway.
For the HD stuff we'll probably up the max bit rate just a little.
Daniel Low
on Jan 18, 2009 at 10:54:02 pm
Actually you should be using a lower bitrate for the HD material and higher for the SD if you want everything to look similar.
Rich Rubasch
on Jan 19, 2009 at 1:52:17 am
Wow, why not encode for BluRay and upconvert the SD material? Seems a shame to take HD, downconvert to MPEG2 and then re-upconvert to HD.
Shame.
Get Toast 9 and bring all of your movies there and burn a Blu Ray disc onto standard DVD-R media. Buy a $299 Blu Ray player and show it via HDMI off that player. I guarantee everyone will be impressed, and you will have used a $199 program and a 25ยข disc to pull it off.
Works for us.
Rich Rubasch
Tilt Media
