Calculating Encodes
Jaime Quintana
Calculating Encodes
on Jan 16, 2009 at 8:27:38 pm
So, I was wondering if there was a widget or equation of some sort that will let me calculate how big a file will be after encoding, For instance, if I have an HD 1080i 2GB file and I wanted to encode it using motionJPEG-B, is there a way to calculate that? A widget that lets you put in the source file info and select the codec would be ideal. Does that even exist? Or am I going to have to be the one to develop it?
Daniel Low
Re: Calculating Encodes
on Jan 17, 2009 at 11:45:47 pm
http://www.videohelp.com/tools/sections/bitrate-calculators
Ultimately it comes down to datarate x duration
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
