MPEG-1 question
Neal Carter
MPEG-1 question
on Jan 6, 2009 at 9:09:25 pm
A client has requested an MPEG-1 of the project I created for use in PowerPoint. The project was originally shot in HDV and I just don't want the final MPEG-1 file squeezed to 4x3. Any suggestions are greatly appreciated.
Neal Carter
Editor|Videographer
Daniel Low
Re: MPEG-1 question
on Jan 6, 2009 at 11:03:53 pm
Letterbox it?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Neal Carter
Re: MPEG-1 question
on Jan 6, 2009 at 11:11:58 pm
Probably what I'll end up doing, but I was curious if there was any software that could help me get there once the QT file was exported out of FCP.
Neal Carter
Editor|Videographer
Daniel Low
Re: MPEG-1 question
on Jan 7, 2009 at 12:02:48 am
http://digigami.com/megapeg/
There's nothing to stop you encoding to 16:9 MPEG-1 as long as your encoding application supports non-standard resolutions (like cleaner). The problems will be with playing it back.
The real question is why is your client requesting MPEG-1, it's so ancient and so inefficient.
MPEG-4 would be a much better option all round.
