Compression for DVD-Rom
Nathan McClendon
on Jan 5, 2009 at 8:11:39 pm
I apologize if this topic has been covered before, I searched the forum and could not find it. Ok here goes:
I have about 8 hours worth of videos (live filming and software screen shots in the same video) that need to go onto a DVD-ROM (not cd-rom because of the amount of video). This is software training that will be delivered through an adobe director movie. I am assuming that h.264 will be the best format for this. I did some tests and h.264 looked good. My question is what will be the best compression setting or compression suggestions for this project?
Current workflow: Export From FCP to Compressor.
Compressor Settings: h.264, Frame rate same as source, height and width same as source, key frame every 30 frames, frame reordering, multi-pass, data rate restrict to 2400kbits/sec, optimized for cd/dvd-rom, aac 48kHz 128kbps, fast start-compressed header, and deinterlace (better -motion adaptive).
The size is good and the quality is acceptable. One of my concerns is the data rate. Is this too much for dvd-rom?
Thanks in advance.
Nathan
Daniel Low
Re: Compression for DVD-Rom
on Jan 6, 2009 at 4:32:45 pm
A 1X DVD drive speed can transfer approximately 1.4MBps (1.36Kbits/s) - You should be able to get good (not great) looking SD H.264 at that datarate, but most people should have faster drives than 1x.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Nathan McClendon
on Jan 6, 2009 at 7:04:58 pm
Just to make sure I under stand correctly; a 2x drive would have a transfer rate of 2.8Mbps...sustained?
Daniel Low
on Jan 6, 2009 at 11:02:43 pm
2.7Mb/s, but I wouldn't say you could 'sustain' that reliably. 2.2 maybe.
Nathan McClendon
on Jan 7, 2009 at 9:44:05 pm
Thats good to know. Thanks for the info!
