Compressor settings for Iphone HD aspect ratio problems
James Mulryan
on Dec 3, 2008 at 10:22:28 pm
Can someone please help me with the following.
Source material:
DVCPRO HD 720 24p quicktime movie from FCP
Want to output to an ipod file. Can't get the right aspect ratio, can anyone please share settings for
getting the proper 16:9 aspect ratio
James Mulryan
Sunset Park Media, LLC
Santa Monica, CA
info@jamesmulryan.com
Daniel Low
Re: Compressor settings for Iphone HD aspect ratio problems
on Dec 4, 2008 at 12:06:27 am
What aspect ratio problems are you having?
Compressors iPhone preset should work fine.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
james Mulryan
on Dec 22, 2008 at 8:50:03 pm
Hi Daniel.
Sorry it took so long to get back to your question. The aspect looks stretched on the horizontal plane when loaded onto my iphone. They also look stretched when I play them back in ituned prior to loading onto my phone.
Thank you.
Jim
James Mulryan
Santa Monica, CA
Peter Axford
on Dec 28, 2008 at 9:49:59 am
You can just use the iPod/iPhone defaults in Compressor 3 - they should automatically letterbox your HD footage or there is an option to anamorph the shots - if it isn't happening change the manually set it. This is what I have been doing the last few days (NB my footage is either widescreen PAL (576/50i) or 1080/50i)
Copied the H.264 for iPod video and iPhone 640x480 (found under Apple > Apple Devices)
Changed "Device" to iPhone (Local/WiFi)
Changed "Aspect Ratio" to 16:9 (480x270)
Changed "Frame Rate" to 25
This is giving me really good results and the beauty is the iPhone screen is 480x320 so it is basically a native format for the screen without the need to up or down scale. You do get black bars top and bottom as the iPhone screen is 3:2 (1.5:1) not 16:9 (1.77:1) but there should be no stretching.
Hope this helps.
james Mulryan
on Dec 28, 2008 at 5:11:48 pm
Hey Peter:
Thanks for the info, will give it a try.
Best,
Jim
James Mulryan
Santa Monica, CA
