Squeeze resize issue
Tim McLaughlin
on Dec 3, 2008 at 8:57:18 pm
I'm trying to make a 800x450 mp4 from a 1280x720 file.
Squeeze is forcing my file to be 800x448, even when I check "unconstrained".
I'm using the Main Concept encoder, AVC Profile is set to "High".
When I use Compressor for the same job, I can set 800x450 easily - but without as many options, of course.
What am I missing?
Tim McLaughlin
Avid and Final Cut Editor
Daniel Low
Re: Squeeze resize issue
on Dec 3, 2008 at 11:44:19 pm
Squeeze is (correctly) constraining the dimensions to be exactly divisible by 4, 8 or 16.
Quicktime H.264 isn't so fussy and as such would result in a lower quality result.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
