squeeze workflow issue
Thomas Wildgen
on Dec 2, 2008 at 2:53:31 pm
I am new to squeeze, but I hope it will be the answer to a huge pile of encoding I do weekly. I am trying to setup the "watch" folder to accept my windows media video and encode it in 4 different bitrates, the last being WMA. I have set up a custom setting under the streaming choices and have that activated in the task window. but I can't get it to do the audio only file! What am I missing? If this is covered in the manual, I apologize, the manual is not very clear on this subject.
Tom Wildgen
WebCast Coordinator
WestLegalEdcenter
Daniel Low
Re: squeeze workflow issue
on Dec 2, 2008 at 4:41:13 pm
Without seeing your squeeze settings this will be very difficult to troubleshoot I would have thought.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Thomas Wildgen
on Dec 2, 2008 at 6:37:24 pm
I believe that I may I solved the issue, It seems that I need to double click the setting once it is in the batch tree to enable the "watch function" once I did that squeeze saw the audio only setting and rendered it.
