compressing HD progressive to SD interlaced for broadcast with compressor
Sean Schiavolin
on Nov 29, 2008 at 9:01:52 pm
Anyone have a solid method for encoding progressive HD (DVCpro HD 29.97) to interlaced SD for broadcast delivery?
I'm using DGfastchannel and their spec's require 480 60i (upper field first) which is causing some serious tearing.
I'm using compressor to encode and viewing the .mpeg with VLC.
Daniel Low
Re: compressing HD progressive to SD interlaced for broadcast with compressor
on Nov 29, 2008 at 11:02:37 pm
"480 60i (upper field first)"
That maybe not quite right:
http://forums.creativecow.net/thread/20/858832
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Sean Schiavolin
on Nov 30, 2008 at 1:08:57 am
as long as there's no issues with delivering a progressive version I'm happy. DG has accepted my compressor encodes even though it's not 4:2:2 chroma.
