Maintaining metadata with Compressor
Scott Davis
on Nov 21, 2008 at 9:17:31 pm
I use compressor a lot for format conversions. We have a lot of metadata attached to the files (inserted in Spotlight comments. Is there a way using Compressor to maintain the metadata from the original file?
Scott Davis
View Scott Davis's profile on LinkedIn
Andy Mees
Re: Maintaining metadata with Compressor
on Nov 22, 2008 at 5:12:37 am
Scott
In the Inspector window's Actions tab you can set Compressor to run a simple Applescript at the end of each encode job
Something along the lines of set the comments of fileA to the comments of fileB should do it.
Cheers
Andy
Scott Davis
on Dec 16, 2008 at 12:42:13 am
Andy, I've been overwhelmed with other work and have just got back to this issue. I have done a very rudimentary study of Applescripting and created a script with "set the comments of fileA to the comments of fileB" in the script editor. Created both a script save and save as application. Tried both and nothing. new spotlight comments are not applied.
Scott Davis
