Compressing from m2v and ac3 combined?
alec gitelman
on Nov 11, 2008 at 9:37:16 pm
I'm using Sorenson Squeeze 5 Pro to produce a number of flash video files from various sources. Some of those sources are compressions for DVDs, i cannot locate the masters of these videos. Is there a way for me to compress using the two files - the split audio and video - produced for DVD building to make one file out of Squeeze other than taking extra steps to create the VOB, convert, etc.?
Thanks.
Alec.
Daniel Low
Re: Compressing from m2v and ac3 combined?
on Nov 11, 2008 at 9:53:48 pm
Try this:
http://www.squared5.com/
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
alec gitelman
on Nov 11, 2008 at 10:16:04 pm
i'm afraid that doesn't solve my issue. mpeg streamclip does not join those files and doesn't even import ac3, unless i'm missing something.
Daniel Low
on Nov 11, 2008 at 10:45:03 pm
I've not needed to do it myself but according to the website:
"It is compatible with MPEG-1 and MPEG-2 video, MPEG layer 1/2 (MP1/MP2) audio, AC3/A52 audio, and PCM audio."
Are you using OS X or Windows?
Ed Dooley
on Nov 13, 2008 at 6:59:10 pm
When you bring a .m2v file into MPEGStreamclip, the AC3 file with the same name goes with it. You can then export it to any number of file types, such as QT to use with Squeeze.
Ed
