Compressor tutorial?
Clara Gordon
on Oct 26, 2008 at 9:42:15 am
Hi!
I'm a new user in Compressor, and I know almost nothing about it. Do you know some Compressor tutorial for beginners? I'd need to know how to convert/compress files.
Clara.
Daniel Low
Re: Compressor tutorial?
on Oct 26, 2008 at 2:14:49 pm
Apples documentation in this case is excellent and in my opinion this manual is the best place to start. There's a full introduction to the UI, the terms used a quick workflow and then how to import media, preview and modify settings and so on. It then goes into specifics on each output format and then gets advanced. (The manual is installed when you install the application)
If you still have no clue after reading through that then you could fork $$ out for this: http://www.rippletraining.com/compressor_products.html
But in my opinion you'll learn more by playing.
Lastly use google or if you are having a problem with something more specific then ask here.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
