switching fields
Bill Macomber
switching fields
on Oct 23, 2008 at 10:51:35 pm
Hi, guys!
I have a client that needs me to deliver MPEG-2 program streams for use in a Grass Valley Turbo system.
Everything is dialed in except for one major problem: I'm coming from DV (lower field dominant) and going to their upper field dominant specs.
Can anybody suggest a workflow that will not give me jittery-frame playback issues? How can I switch the field dominance correctly?
Currently, I come out of Final Cut Pro 6.04 and use Compressor to encode the MPEG-2 file. I am using Compressor to set the field dominance to upper, setting it in the inspector at the encoder menu>video format>field dominance>upper.
Bill
Daniel Low
Re: switching fields
on Oct 23, 2008 at 11:35:16 pm
Have you tried switching it in the FCP browser?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
