Apple Compressor 16:9 framesize ?
Sieger Duinkerken
on Oct 17, 2008 at 2:48:29 pm
i'm a bit confused about 16:9 framesizes.
my dvpal file is 720x576 anamorphic.
when I use Compressor to convert it to MPEG2 16:9, the file is 720x404. I lose pixels.
shouldn't it still be 720x576 pixels (and afterwords stretched in the dvd or whatever-player) ?
Compression documentation doesn't make this quite clear for me, so I hope someone could tell me how it works :) thanks!
Ed Dooley
Re: Apple Compressor 16:9 framesize ?
on Oct 17, 2008 at 2:57:53 pm
The trick is to not believe what QT is telling you. It looks at the PAR flags and says it's 720x404 when in fact it's 720x480 anamorphic. Look at it through MPEGStreamclip (a free app if you don't have it), and it will show you that it's correct.
Ed
Sieger Duinkerken
on Oct 17, 2008 at 3:00:13 pm
wow, thanks for your quick reply! :)
Ed Dooley
on Oct 17, 2008 at 3:02:39 pm
You're welcome!
Daniel Low
on Oct 17, 2008 at 4:05:19 pm
Actually it would be 720x576 if you use the (superior) PAL format rather than the 720x480 of NTSC.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Ed Dooley
on Oct 17, 2008 at 4:09:09 pm
Yes, that's true, but same point, same result. I'm so U.S. centric. :-)
Ed
[Daniel Low] "Actually it would be 720x576 if you use the (superior) PAL format rather than the 720x480 of NTSC.
