converting HDV to H264 using compressor 3
Geo Monterosa
on Oct 14, 2008 at 7:03:05 pm
After converting HDV to H264 using the default settings, I opened the movie through Quicktime and the frame was 4x9 instead of letter box frame of original source. I checked the default settings of H264 in compressor and the frame setting is 1440x1080, the same as the original source. Is this normal?
Daniel Low
Re: converting HDV to H264 using compressor 3
on Oct 14, 2008 at 9:38:06 pm
You don't say what you want to deliver, or to whom?
Is it for web delivery, IPTV, Broadcast transmission or mobile device?
Just so you know, HDV uses non-square pixels to deliver a 16:9 image so 1440x1080 non-square pixels equals 1920x1080 square pixels.
1440/1080 = 1.333:1 or 4:3 - Rectangular pixels
1920/1080 = 1.777:1 or 16:9 - Square pixels
Bottom line is that 1440x1080 is HDV's way of 'cheating' 16:9 Full HD video.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
