DVCPro50 squished by compressor mpeg4
Jonathon Fulton
on Oct 1, 2008 at 7:42:49 pm
I have some footage shot on an HVX200 - DVCPro 50 at 480i. I exported from Final Cut Pro 6.04 using export as QT movie. Then opened that in Compressor.
I tried Compressor setting of Mpeg-4 but the footage has come out squished.
Why would that be when the frame size is set to 100% of source and the pixel aspect is set to default for size?
Daniel Low
Re: DVCPro50 squished by compressor mpeg4
on Oct 1, 2008 at 9:01:01 pm
DV uses non-square pixels, MP4 uses square pixels. Solution, set the output frame size aspect ratio to match the source aspect ratio, not the source frame size,
I.e. 720x480 non-square source = 640x480 square output.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
