*Cannot connect to background processing* error message
Jonathan Holtz
on Sep 3, 2008 at 6:10:31 pm
Hey all, I'm trying to compress a 75 minute video out of Final Cut using Compressor. I can successfully create a batch with the necessary settings and destinations, but when I try to submit the batch, the error message *Cannot Submit Batch: unable to connect to background processing* appears. I clicked on file/Reset Background Processing... and recreated the batch, and tried to submit the batch again, to no avail.
Any help with troubleshooting this?
thanks,
Jonathan Holtz
Daniel Low
Re: *Cannot connect to background processing* error message
on Sep 3, 2008 at 9:24:09 pm
A typical problem and one of the reason I, like many, gave up with compressor. You could try and check you Qmaster settings and as a last resort reinstall compressor.
http://support.apple.com/kb/TS1888
http://discussions.apple.com/thread.jspa?messageID=6583531
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Ed Dooley
on Sep 4, 2008 at 3:51:33 pm
It's been discussed many many times on the COW. Enter that exact phrase in the COW's search or Google and you'll get lots of hits.
Here's one of dozens of good ones:
http://docs.info.apple.com/article.html?artnum=93234
Ed
