Can crop out action-safe areas AND resize to 320x240 in expression encoder or otherwise?
chon teck
on Aug 29, 2008 at 1:54:26 pm
Hi All,
I need to compress a 768x576 avi into a 320x240 wmv using expression encoder 2.
However, I would also like to crop out the action-safe areas of the source avi file (about 5% on each of the four sides) so that the 320x240 output file gets "closer" to the action.
My efforts so far have not been successful since in expression encoder, I have been able to do only either resize or crop but not both at the same time (The cropping seems to override the resize options).
Can anyone suggest a solution or an alternative using other software?
Thanks in advance!
Daniel Low
Re: Can crop out action-safe areas AND resize to 320x240 in expression encoder or otherwise?
on Aug 29, 2008 at 2:55:26 pm
In the Crop settings under video profile, do you have 'Sync Size to crop' checked?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
chon teck
on Sep 2, 2008 at 1:16:02 am
Update:
Thanks Daniel!
Was confused by what seemed to be repeated settings in the interface.
Here's what worked:
(1)In Video Profile>Crop, 'Sync Size to crop' needs to be deselected
(2) In Video Profile>Crop, specify the amount and positioning of crop as needed
(3) In BOTH Profile>Video and Video Profile>Size, enter output resolution as needed.
