Is there such a thing as H.264 transport stream?
Arthur Puig
on Aug 13, 2008 at 11:16:38 pm
Is there such a thing as H.264 transport stream? Or a transport stream applies to MPEG2?
If there is, which software can I use? I haven't seen anything that allows me to do this in Compressor
Daniel Low
Re: Is there such a thing as H.264 transport stream?
on Aug 14, 2008 at 6:59:50 am
Typically H.264 is used within an MPEG-2 transport stream.
You haven't been very clear on what you are trying to achieve but if you want to do the above then you'll need Telestream Episode Pro.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Arthur Puig
on Aug 14, 2008 at 7:42:17 pm
Basically I need to create an AVC transport stream with constant bitrate and it shall consist 188 byte packets, and I have a lot more of specs I don't understand yet, but, so far the enly encoding software I have is Apple Compressor and Cleaner 6.5, and I don't think they can do this, at least I tried and couldn't get Compressor to allow me to select constant bitrate (it was greyed out) for a dimension of 1920 X 1080.
Do you think the software you previously mentioned can do this?
Thanks so much!
Daniel Low
on Aug 14, 2008 at 9:40:02 pm
Neither compressor or cleaner can do what you want. Compressor might in the future, cleaner will never.
Episode, I've been informed can do it. Contact Telestream, send them your spec and get them to confirm.
Arthur Puig
on Aug 15, 2008 at 2:08:21 am
Great, thanks for the info!
Egen Amas
on Aug 25, 2008 at 1:14:02 pm
hi,
Just out of curiosity, are you working for Microsoft media room?
well these can do what you need, happy testing :-)
http://www.elecard.com/products/products-pc/professional/converter-studio-p...
http://www.mainconcept.com/site/
http://www.ateme.com/bb/products.php5?Arg=1
