GOP Structure
bruno silva
GOP Structure
on Aug 7, 2008 at 9:41:17 pm
Does anyone know the difference between these GOP structure and what they even mean? IBBP IBP IP, I came across these while using Compressor and messing with the options in the dvd settings.
Assistant Editor
http://www.harringtontalents.com
Craig Seeman
Re: GOP Structure
on Aug 7, 2008 at 10:18:22 pm
See this brief description.
GOP - Group Of Pictures.
GOP - Begins with an "I" frame, followed usually by a number of "P"
and "B" frames
- GOP's can be as small as a single I frame, or as large as
desired, but usually no more than 15 frames in length.
- the longer the GOP, the more efficient, but less rubust the
coding
I frame - "Intra-coded" frames
P frame - P frames are predicted based on prior I or P frames
B frame - Bidirectionally predicted frames based on appearance and
positions of past and future frames
