encoding for Blackberry Pearl
Scott Davis
on Jul 17, 2008 at 12:55:53 pm
Does anyone have a recipe for encoding movie files for the Blackberry Pearl? Dimension, codec, bit rate, etc?
Thanks in advance,
Scott
Scott Davis
View Scott Davis's profile on LinkedIn
Daniel Low
Re: encoding for Blackberry Pearl
on Jul 18, 2008 at 2:25:44 pm
The following Video formats are supported:
* MPEG-4 Part 2 - Simple Profile + bvops (including DivX files in this format)
* H.263 Profile 0 and Profile 3
The following Video file extensions are also supported:
* .avi containing MPEG4 Part 2 and H.263
* .mov containing MPEG4 Part 2 and H.263
* .3gp containing MPEG4 Part 2 and H.263
* .mp4 containing MPEG4 Part 2 and H.263
* .m4v containing MPEG4 Part 2 and H.263
* .mpg containing MPEG4 Part 2 and H.263
MPEG-4 is obviously better than H.263
According to Blackberry themselves these are the transcode settings:
Video format: MPEG-4
Video file extension: .AVI
Resolution (4:3): 240x180
Resolution (16:9): 240x135
Video bitrate: 400 kbps
Frames per second: 24
Audio format: MP3
Audio bitrate: 128 kbps
Sample rate: 44 khz
Channels: 2 (Stereo)
I'd suggest you can at increase the bitrate and frame rate if needed.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
