How to improve my conversion methode from HDV format to Web diffusion
Foucault Martial
on Jul 12, 2008 at 9:54:51 am
Hi to all and thanks, since I'm in this group I lhave learned too
much... but not enought.
Please, can you help me to improve my conversion process.
I would like to publish my video on the web in "Normal quality" and in
"High def Quality", so for low and speed connection.
Actually I use footage from Sony HVR-HD1000P
1080 50i.
1 - I capture m2t files with HDV Split (sceene detect on)
2 - I open a HDV1080i25 (50i) Pal project on Ppro CS3
3 - I import my media, edit in the timeline and ....(wait for the red
line ;))
At the end
4 - I export in:
Quicktime (Animation codec)
640x360 (16:9)
square pixel
deinterlace
5 - I convert in Squeeze Sorenson to .flv in 640x360.
I'm shure I can have better quality with less big files.
Personnaly I prefere use flv format for the web, there is less
conflict for compatibility.
Why not ? Pourquoi pas?
Win XP SP2
AE CS3
Ed Dooley
Re: How to improve my conversion methode from HDV format to Web diffusion
on Jul 12, 2008 at 12:33:36 pm
I export a QT using current settings (not scaling it or putting it into the Animation codec or deinterlacing), so I get a full resolution QT. Bring that into Squeeze and apply size, deinterlace, etc. there, et voilĂ !. What .flv codec are you using in Squeeze (and what version of Squeeze)? You should be using the ON2VP6 codec. If you don't have that you should get the option or update Squeeze. Flash quality won't be good without ON2VP6.
Ed
[Foucault Martial] "At the end
4 - I export in:
640x360 (16:9)
square pixel
deinterlace
conflict for compatibility.Why not ? Pourquoi pas?
Win XP SP2
AE CS3
Foucault Martial
on Jul 12, 2008 at 4:02:22 pm
I don't anderstand well,
So, how are yours current QT settings ? codec ... ?
Win XP SP2
AE CS3
Ed Dooley
on Jul 12, 2008 at 4:16:05 pm
You have 2 ways to export to QT from FCP. The 1st one is to Export to QuickTime (either selecting Save As Self-Contined, or as a reference QT), the 2nd way is to Export To QT Using Conversion. Choose the 1st way and use Current Settings and you're exporting in the same codec you edited in. All the sizing and deinterlacing is done in Squeeze.
Ed
Foucault Martial
on Jul 12, 2008 at 8:04:02 pm
Thanks Ed,
The thing is I work on Premiere Pro CS3... ;)
Win XP SP2
Ppro CS3
AE CS3
Ed Dooley
on Jul 12, 2008 at 8:27:31 pm
Sorry, I didn't see the AE CS3 tag (and I see you added the PPCS3 just on your last post!). But I should have gotten a clue when I saw XP. :-)
Why aren't you exporting directly to Flash from CS3? The ON2VP6 codec is included in the Export to Adobe Encoder.
Why are you going to Squeeze, do you like the extra step, or do you think the quality is better?
Ed
