Best settings for Sorenson Squeeze / iDVD
Simon Miller
on Jul 5, 2008 at 12:30:24 am
Hi everyone,
Newbie on here, and hoping someone can help!
I've got a sequence I need to get from Avid Adrenaline into iDVD via Sorenson Squeeze this week. It's a PAL 16:9 standard definition project. The sequence itself is only 30' long so I'm hoping I can do it in pretty high quality.
Does anyone know the best settings to use in Squeeze to get the best results into iDVD? I know iDVD is limited in the formats it can take in.
Any help would be much appreciated! I'm just not sure which format to get Squeeze to export to. I have googled around for what seems like hours and have done a search in forums here but can't seem to find the answer.
Thanks in advance!
Daniel Low
Re: Best settings for Sorenson Squeeze / iDVD
on Jul 6, 2008 at 9:31:21 pm
What format are you working with?
HDV? DVCPRO HD? XDCAM?........
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Simon Miller
on Jul 8, 2008 at 5:54:34 pm
I got it worked out through trial and error in the end actually - just chose a Quicktime HD720 export setting, selected 16:9 in the drop down menu at the top of the app, and then changed the HD720 settings to export at 720 x 576.
Worked a charm, but thanks for getting back to me!
Simon
