FCP and FLVs and Compressor, oh my!
Jim Britton
on Jun 24, 2008 at 9:35:34 pm
Hi all,
I'm trying to encode an flv using Compressor. The compression worked with one exception - the audio makes a "clicking" noise...and after about 5 seconds, it's out of sync. I've not been able to figure out why this continually happens. I employed a successful workaround (export a qt movie and use flash encoder), but I'm just curious if anyone knows why this could be happening...
I'm using Compressor 2.3.1 and FCP 5.1.4, running 10.5.2.
Cheers,
Jim
Kris A. Wotipka
Re: FCP and FLVs and Compressor, oh my!
on Jun 26, 2008 at 4:46:03 pm
I am doing a project where everything is ending up as .flv files. I am exporting the files as 320x240 QT animation Millions+. Separate XML data for cuepoints. From there they go into the Flash Media encoder. Doing just a bit of cropping on the top and bottom to give them a "wider screen" look. 200kb/s deinterlaced in Flash gives me around 2MB/minute finished. Everything stays in sync and looks good considering the hit they are taking in compression.
kris@wotipka.com
Image maker
