compression for non standard movie files
jamil Yamani
on Jun 20, 2008 at 4:28:45 am
Hi all
Is there anyone out there using a Mac and also authoring for non-standard frame sizes? it seems that the mpeg2 format has some limitations re frame size when exporting from compressor.
what i mean is that if i had a file that was 1000 x 3000 pixels and i try to export to mpeg2 through compressor, then compressor would alter the pixel dimensions to 720 x 576
is anyone using different software to accomplish this task, like cleaner or something i haven't heard of?
thanks
jamil
g5 intel multi etc
The Electric Canvas
Large Format Projection Specialists
Sydney, Australia
Daniel Low
Re: compression for non standard movie files
on Jun 20, 2008 at 11:53:53 am
It's very unlikely that you'll find a transcoder that will work to non-standard resolutions like that, but you can give this a try -
http://www.digigami.com/megapeg/index.php
Even if it does produce files to that resolution it's even more unlikely that you'll find anything that can play them back!
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Daniel Low
on Jun 20, 2008 at 12:04:02 pm
If you're producing files for OnlyView then I think you're going about it the wrong way. Onlyview tiles images and video together to produce the huge and odd sizes they project.
You should contact them to see exactly what they work with.
