Compressor frame controls????
jamil Yamani
on Jun 17, 2008 at 12:19:42 am
Hi there
I am using Compressor to turn out some mpeg2 files. however i am not working in standard pixel resolutions such as 720 x 576 etc. in the geometry settings in the inspector pallette the dimensions field is greyed out, this means i can't set the output pixel dimensions!
does anyone know how i can access these controls? any help would be very appreciated?
thank you
jamil
Daniel Low
Re: Compressor frame controls????
on Jun 17, 2008 at 7:00:43 am
Check page 186 of the compressor 3 manual - it's all explained clearly in there. If you are using compressor 2 just check out the MPEG-2 section.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
jamil yamani
on Jun 17, 2008 at 7:29:30 am
hi danny
thanks for the info, i had looked that up previously i just thought there may have been a work around. encode view and main concept both offer control over the frame size. this is not an option in compressor if you are exporting to mpeg2.
i wish that wasn't the case as i am encoding for onlyview (multi screen, multi format etc etc) = unusual frame sizes
best + thanks
jamil
The Electric Canvas
Large Format Projection Specialists
Sydney, Australia
