Dimensions keep changing??? It is breaking my brain!!!!
Natasha O'cconor
on Jun 4, 2008 at 12:31:57 am
I have a clip and I go to the "get info" box and it reads that the dimensions are 720x576.
I then go to QT and look in the info material box there and my dimensions are now 1024x576? What does this mean?
Rich Rubasch
Re: Dimensions keep changing??? It is breaking my brain!!!!
on Jun 4, 2008 at 2:40:53 am
I think you are seeing the actual dimensions of the clip (720 x 576) in the get info box, and in QT you are seeing the DISPLAY dimensions, 1024 x 576. Sounds like anamorphic footage. It is squeezed horizontally for capture, but would be displayed at the wider frame size for the correct aspect.
Rich Rubasch
Tilt Media
Ben Waggoner
on Jun 4, 2008 at 3:56:09 am
And in fact 1024x576 is the default display resolution for PAL 16:9 (720 * 1.7777 = 1024)
Ben Waggoner
Principal Video Strategist, Silverlight
Microsoft Corporation
Compression Blog: on10.net/blogs/benwagg/
Compression Classes at Stanford and PSU: on10.net/blogs/benwagg/21622/
Natasha O'cconor
on Jul 7, 2008 at 10:14:27 am
ok ok - So I am TRYING to export Mpeg 2s Multiplexed 720x576 16:9. Every-time I export I see the footage as 720x404? I am entering my works ads competition and their requirements are 720x576 16:9. I have tried everything and it is due now! Just have to get them in my midnight tonight. Somebody out there can put me straight again..?
Brian Alexander
on Mar 24, 2010 at 3:43:28 am
Did you ever find a solution to your problem? How did your submission go?
Here's what I'm seeing from this end (although it's a moot point); the 720 x 576 (1024 x 576) is a PAL based frame. The 720 x 404 sounds like a 16:9 letter-boxed image in a 720 x 480 NTSC frame.
Just thought I'd throw it out there.
Brian Alexander
Sr Video Engineer
Freeman AVS
