 | Compression Book to buy?
on May 27, 2008 at 3:03:49 am |
I am in desperate need of help with working out the settings I need to use when compressing clips.
A book that can talk me through different setting techniques for resizing and compressing my video clips. At the moment I am reading every forum to do with Sorenson Squeeze, Episode Pro, After Effects, Photoshop CS3 and Final Cut Pro.
My work flow is - resizing and / or compressing clips for the web, dvds and tv.
They are normally asking for Flash, QT and Mpeg-4s.
I know there is not one "all in one setting" but what book can I buy that will be able to teach me the things I need to know in order to do these things with ease and confidence oh and SPEED!
Hope this all makes sense..
 | Re: Compression Book to buy? on May 27, 2008 at 8:56:40 am |
It's a bit out of date but this is a great book:
http://library.creativecow.net/articles/handy_jeff/comp_book_rev.php
Otherwise, working through the posts here is your best bet.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
 | Re: Compression Book to buy? on May 27, 2008 at 9:50:23 am |
Thanks for that.
Sometimes you just need someone to say which book or what ever to get. A lot of info out there, it can bend ones brain a little at times.
Thanks again!!
 | Re: Compression Book to buy? on May 27, 2008 at 4:17:57 pm |
It's a DVD-ROM tutorial and it's specific to Compressor but that may be useful to you if you're going the FCP/Compressor route.
http://www.rippletraining.com/the_art_of_encoding_with_compressor.html
This DVD is for Squeeze 5
http://www.sorensonmedia.com/pages/?pageID=97
 | Re: Compression Book to buy? on May 27, 2008 at 8:20:38 pm |
not to schill my own book, but i did just have a book on compression published by Peachpit called Real World Video Compression. I think the cheapest price on its on Amazon right now:
http://www.amazon.com/Real-World-Video-Compression/dp/0321514696/ref=pd_bbs...
Brian's Ripple Training is great by the way - if you are specifically using Compressor, I suggest trying it out.
