H.264 compression ratio
Mike Sato
on May 9, 2008 at 5:12:23 am
Two questions:
1. Anyone know what the approximate compression ratio is when a digital still camera uses H.264 to compress a 1280x720 video into a .mov file?
2. If the average playback bit rate for 720x480 video on a standard DVD is 5 Mb/sec, what would the approximate MPEG-2 compression ratio be?
Daniel Low
Re: H.264 compression ratio
on May 9, 2008 at 12:10:05 pm
1. Depends on the specs of the camera.
2. Depends on the source.
A = source
B = compressed output
Compression ratio is how much is 'A' compressed by to become 'B'
http://en.wikipedia.org/wiki/Ratio
http://en.wikipedia.org/wiki/Video_compression
http://en.wikipedia.org/wiki/Image_compression
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Mike Sato
on May 10, 2008 at 8:20:19 pm
Daniel,
Thanks for your response. I am still unable to get even approximate answers to my two questions from those links though.
Mike S.
Daniel Low
on May 11, 2008 at 1:04:12 am
OK
I'll try answering it in this way:
1. How many Megapixels is the camera and how many megabytes does 1 minute of 1280x720 H.264 video from that camera take up in space?
2. What is the format, frame size and datarate of the source you used to create the MPEG-2 and how long is it in total?
Daniel Low
on May 11, 2008 at 1:19:09 am
Actually, thinking about it, it's impossible to answer question 1 without specific technical specifications for the camera.
Mike Sato
on May 11, 2008 at 7:32:49 pm
> 1. Anyone know what the approximate compression ratio is when a digital still camera uses H.264 to compress a 1280x720 video into a .mov file? <
>> Actually, thinking about it, it's impossible to answer question 1 without specific technical specifications for the camera. <<
OK. Just looking for a ballpark answer if anyone has an idea.
> 2. If the average playback bit rate for 720x480 video on a standard DVD is 5 Mb/sec, what would the approximate MPEG-2 compression ratio be? <
>> 2. What is the format, frame size and datarate of the source you used to create the MPEG-2 and how long is it in total? <<
Say a commercial DVD movie that is 2 hours long and has wide screen or 4:3 full screen pan & scan viewing options.
