DVB Standard Encoding
Yehuda Brandriss
on Apr 13, 2008 at 7:40:32 am
Is there a Software based encoder that fully conforms with DVB Standards for Transport Streams?
My conclusion so far is that there is no such software, can anyone confirm or counter this conclusion?
Daniel Low
Re: DVB Standard Encoding
on Apr 13, 2008 at 12:08:17 pm
DVB is a transmission method but pretty well any software transcoder that fully supports MPEG-2 Main Profile at Main Level (MP@ML) will produce 'compliant' streams.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Yehuda Brandriss
on Apr 13, 2008 at 2:14:27 pm
So far in the software encoders that I have used we are missing certain bits from the Transport Layer, such as the PSI (Payload Start Indicator), and a few others.
Daniel Low
on Apr 13, 2008 at 5:11:06 pm
In which case you'll probably need to look at adding something like the Manzanita Enhanced Multiplexer to your favorite transcoding package.
http://www.lilapple.com/products.html
Yehuda Brandriss
on Apr 14, 2008 at 11:26:42 am
Thanks, I will try it out.
Ben Waggoner
on Apr 19, 2008 at 3:11:53 am
Rhozet's new Carbon Coder 3 they announced at NAB also looks quite promising in its ATSC/DVB features. Integrated AC-3 encoder as well.
Ben Waggoner
Principal Video Strategist, Silverlight
Microsoft Corporation
Compression Blog: on10.net/blogs/benwagg/
Compression Classes at Stanford and PSU: on10.net/blogs/benwagg/21622/
