Fast motion on You Tube
Eric Yukshro
on Apr 9, 2008 at 3:01:39 am
I just finished making a movie and tried a lot of the different compression settings recommended for YouTube videos and the multiple file uploader to no avail.
My video starts off slowly (~10 FPS) and speeds up to 900% of normal speed. Here's my problem: When it starts off slow, it looks great but when it speeds up it looks very horrible and pixelated.
If someone could help out I'd appreciate it!
Daniel Low
Re: Fast motion on You Tube
on Apr 9, 2008 at 10:04:51 am
Youtube's transcoding methods simply can't handle complex video without falling apart. That said, can you post a link to your video so we can confirm that's the issue?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Eric Yukshro
on Apr 10, 2008 at 1:31:48 am
Actually, I deleted the video because the quality was so bad. Yes, it was that bad.
I can upload a test movie if you'd like - but I don't want to put the actual movie up because the perfectionist in me won't allow it, until the quality is satisfactory.
Daniel Low
on Apr 10, 2008 at 9:14:57 am
If you're a perfectionist, stay well clear of Youtube, they get many things badly wrong.
Craig Seeman
on Apr 10, 2008 at 4:19:58 pm
If you need quality try
http://www.vimeo.com/
It's YouTube the way it should have been done (more or less) they can accept and play 720p30 HD (as well as SD). They use On2VP6 codec. They give you the option to allow the viewer to download the original source file you uploaded (Hence, it's good for both viewing and delivery).
YouTube's one advantage is its viral value since it shows up high in the Google search engine (for obvious reasons).
If you're showing files for business reasons, Vimeo is much better.
