16X9 Compression
Tony Luke
16X9 Compression
on Apr 7, 2008 at 7:27:36 am
Hey guys - just looking for some advice. I need to compress 4:3 into 16:9, without the distortion that it creates. Instead, I need it to simply cut off the top and bottom and output it into the shape of a typical 16:9 quicktime. Thanks a lot!
Daniel Low
Re: 16X9 Compression
on Apr 7, 2008 at 8:58:38 am
Too vague, what applications are you using or do have available to use?
What is your source and what is your destination format?
Typically for 4:3 material in a 16:9 you would 'pillarbox' the 4:3 clip rather than 'cutting' it into the 16:9 frame size.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Tony Luke
on Apr 7, 2008 at 2:56:55 pm
Hey sorry about that mate!
I'm using Compressor and need to compress it into a quicktime that is 16:9, without distorting the actual video itself, merely cropping the top and bottom.
Craig Seeman
on Apr 7, 2008 at 4:09:32 pm
Your best bet would be doing the crop in your NLE (Final Cut Pro). This way you can reposition the video for best framing in the crop. This wold give you the letterbox look (black on top and bottom). You could do that an then crop off the black in Compressor.
Daniel Low
on Apr 8, 2008 at 3:04:15 pm
Personally I wouldn't want to crop it to fit, I'd want to pillarbox it (the opposite of letterbox). Compressor calls this 'Padding', have a look at page 273 of the compressor 3 user manual for details.
Tony Luke
on Apr 7, 2008 at 2:56:57 pm
Ed Dooley
on Apr 7, 2008 at 4:06:04 pm
So what's the question? Use Compressor to crop it.
Ed
Tony Luke
on Apr 8, 2008 at 11:13:51 am
yes... well.. thats the question. im confused on how to do it. Source inset, dimensions? everything ive tried has rendered useless
