quicktime to idvd
john napier
quicktime to idvd
on Apr 6, 2008 at 11:02:29 pm
Hi Guys,
I would be greatful if you could help me out:
Because of the chapter issue with imovie7 i have to export my movie to Metadata Hootenanny to insert chapters, (no problem) but What i would like to know is what are the best settings in quicktime for exporting data which lasts 1hour and 27 minutes, quality is very important as its a friends wedding dvd.
Thank you for time guys.
J.
Daniel Low
Re: quicktime to idvd
on Apr 7, 2008 at 8:55:10 am
What was it shot on? DV?
If so, export it as that, if not, export it at whatever the source is/was, no point in adding an additional transcode step.
Did I understand your question correctly?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
john napier
on Apr 7, 2008 at 9:15:48 am
Thanks for your help daniel
john napier
on Apr 19, 2008 at 8:34:47 pm
DV quality is fine, however, the size is 17GB, is there any way of compressing it down in quicktime but still retaining the high quality?
j
john napier
on Apr 21, 2008 at 1:46:49 pm
j
Daniel Low
on Apr 21, 2008 at 1:56:55 pm
You could try the MotionJPEG B codec. If your source is progressive use the PhotoJPEG codec.
