Squeeze crashes
Tom Nelson
Squeeze crashes
on Mar 28, 2008 at 7:38:07 pm
I'm trying to compress an FLV and a SWF from Squeeze 4.3 off of an uncompressed QT file out of Avid. When I try to adjust the presets, no codecs show up for audio. When I try to compress as-is, Squeeze crashes. I've already tried uninstalling and re-installing Squeeze - no luck. Any ideas?
FYI - I've done the same process (I believe it's the same process) on other edit suites with good results.
-Tom
del chapple
Re: Squeeze crashes
on Mar 28, 2008 at 9:53:52 pm
Is the squeeze on the avid? if not you might need to load the avid codec on the squeeze computer..
d
you cant hear my inner voice scream... can you..?
