After encoding, first frame has turned green
David Schneider
on Mar 19, 2008 at 4:14:44 pm
I used Compressor with this method at Ken Stone's site to encode a video for YouTube: http://www.kenstone.net/fcp_homepage/youtube_compressor_gary.html
For some reason, in the resulting quicktime, the first frame, where it's supposed to be solid black, is a sickly green. I've double checked that I was following all the settings in the tutorial, and I've I've examined my original video... the first few frames are definitely supposed to be solid black (it's 2 seconds of black slug directly from FCP).
Any ideas on what might be causing this, and how to get rid of it?
Daniel Low
Re: After encoding, first frame has turned green
on Mar 20, 2008 at 9:56:41 am
Do you get the same result when encoding to a different CODEC?
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
