Creating HD MPEGs
Sanjay Chalisey
Creating HD MPEGs
on Mar 5, 2008 at 11:25:19 am
Hello,
I've been asked to create HD MPEGs based on the following dimensions:
Pixel Dimensions: 1920 x 1080
Frame Rate: 25fps
Bitrate: 36 mbit/s CBR
Profile: Main
Level: High
VBV Buffer Size: 488
Closed GOPs
N Value (Number of Frames in GOP): 15
M Value (Number of Frames Between Anchor Frames): 3
Sequence Header Interval: Each GOP
Video Encode PID: 16
If you look at the settings, Compressor (as far as I know) cannot achieve this. For example, If I choose the MPEG-2 or the HD MPEG presets and then try to adjust these (after duplication), I cannot change the bitrate settings from VBR to CBR as an example.
Would be grateful if another encoding application can be recommended for the apple mac (does Pixel Tools have a mac version of their MPEG encoding software for example?).
Many thanks in advance.
Sanjay Chalisey
7 Continents Productions
Daniel Low
Re: Creating HD MPEGs
on Mar 5, 2008 at 12:50:58 pm
Take a look at this, it does what you need:
http://www.digigami.com/megapeg/features.php
You might also want to check out Episode Pro from Telestream.
Please post back saying what solved your problem. It could help others, and saying 'thanks' is free!
Sanjay Chalisey
on Mar 5, 2008 at 2:12:02 pm
Thanks Daniel.
Will update you once I've made progress on this.
Appreciate the help.
Rich Rubasch
on Mar 6, 2008 at 1:09:55 am
Somehow I could do this...I don't recall what I did. I think it depends on which preset you start with, duplicate it and then adjust the settings. I had to make a similar MPEG and at first I could not change the VBR setting.....later I tried again and I could select CBR no problem.
Again it depends on which preset you start with (can't recall) and how you change the settings.
I loathe compressor.
Rich Rubasch
Tilt Media
del chapple
on Mar 11, 2008 at 3:18:47 am
You are probably going to have to invest in another program. I'm sure episode will do this but does episode do hd..? I use Rhozet which is a pc program, you can pretty much make anything m2t's to flash etc, sound like you need a transport stream because of the pid but there is also a need for a audio program id..
del
you cant hear my inner voice scream... can you..?
