MPEG compatible w/ QT
Adair Simon
on Feb 5, 2008 at 6:13:23 pm
I created a FCP one minute video for a client that wants to put it on his website with an MPEG format that is compatible with Quick Time and the file needs to be non-compressed AVI.
I compressed it in Compressor with the Web Videocasting in the QT application rather than the MPEG. Does this fit their requirements?
Daniel Low
Re: MPEG compatible w/ QT
on Feb 6, 2008 at 9:49:08 am
No it doesn't. If the client wants MPEG then the client should get MPEG, not just a .Mov or whatever.
It should be either MPEG-1 or MPEG-4, both are totally compatible with Quicktime, MPEG-4 will give you higher quality for a given datarate than MPEG-1, but MPEG-1 will play well on computers that are too old and underpowered for MPEG-4.
Some background on MPEG:
http://en.wikipedia.org/wiki/MPEG
You are interested in MPEG-1 and MPEG-4 part 2 and part 10, part 10 is also called H.264.
Adair Simon
on Feb 7, 2008 at 3:52:20 pm
Thanks for your response and the wikipedia link.
Adair
Adair
