Help..Sorenson Squezze introducting noise into my footage?
Josh J. Johnson
on Jan 30, 2008 at 9:51:30 pm
when I compress my footage in sorenson with the avc codec it introduces a lot of noise that wasn't there. Is there some kind of preset causing this? What am I doing wrong. I'm using 4.5 but when I had 4.3 this problem didn't seem to happen?
thanks
Daniel Low
Re: Help..Sorenson Squezze introducting noise into my footage?
on Jan 31, 2008 at 2:01:22 pm
Can you describe the noise in a bit more detail - is it like snow, blocks, fizzing, or are you referring to actual noise on the audio tracks?
Josh J. Johnson
on Jan 31, 2008 at 7:43:24 pm
Thanks for the reply. It's like snow/fizzing and when I do see blocks I thing that is just a data rate issue.
Josh Johnson
Manager of Video Production
ETC, Inc.
