Can Apple's Compressor meet DGFastchannel specs?
Christian McIlwain
on Jan 8, 2008 at 9:50:22 pm
Or do I have to buy a new program?
Daniel Low
Re: Can Apple's Compressor meet DGFastchannel specs?
on Jan 9, 2008 at 10:15:10 am
Do a search in this forum, there's been a ton of posts about DG FastChannel
Fred Connors Jr
on Jan 10, 2008 at 6:25:25 pm
Last time I checked Compressor would not do it.
We use Episode.
Fred
The Troupe - Modern Media Design & Production
DoctorSney
on Jan 11, 2008 at 1:05:29 am
I've successfully used compressor 3.02 to crunch a spot that DG Fast Channel accepted no problem. The world did not end, all was good.
it wasn't exactly their specification, but I tweaked it so that hopefully it wouldn't exceed their boundaries.
here are the settings I'm using:
Name: Fast Channel - MPEG-2
Description: For Sending to DG Fast Channel
File Extension: mpeg
Estimated file size: 6.75 GB/hour of source
Type: MPEG-2 program stream
Video Encoder
Format: M2V
Width: 720
Height: 480
Pixel aspect ratio: NTSC CCIR 601/DV
Crop: None
Padding: None
Frame rate: 29.97
Frame Controls: Automatically selected: Off
Start timecode from source
Aspect ratio: 4:3
Field dominance: Automatic
Average data rate: 15 (Mbps)
2 Pass VBR enabled
Maximum data rate: 18 (Mbps)
High quality
Best motion estimation
Closed GOP Size: 6, Structure: IP
Audio Encoder
Format: MPEG
Sample Rate: 48.000kHz
Channels: 2
Bits Per Sample: 16
I used the 'IP' structure for the GOP because I had a lot of fast motion in my spot and there was some freezing of the picture just as the spot started. Actually I think I fixed that by shaving three frames off the slate of the spot so that the 'I' frames would fall in different locations, and that seemed to work great...after 2 f*ing hours of experimenting with different GOP settings...
I use size 6 GOP, I figured it was alright as long as it didn't go over Fast Channels specification of 9 GOP.
All I'm saying is that you can use the other frame structures such as IBBP, or IPPPPP or IPB or whatever, just don't select 15 for your GOP size. 9 is greyed out, but I'm pretty sure you're allowed to go lower, and not higher, and my spots weren't rejected so my theory must be right?
hope this helps people :)
cheers
Sney /
Matt Steeves
on Jan 18, 2008 at 3:45:24 pm
No, compressor cannot do the job unfortunately. It can't render an mpeg with 4:2:2 color space and make the frame size the required 720x512. We had to buy Episode from flip4mac.com to get certified.
Apple Certified Final Cut Pro 6
Mac Pro 3.0 Quad
Kona LHe
Panasonic HPX-2000
Craig Seeman
on Jan 18, 2008 at 3:53:10 pm
And I'm testing an Episode "patch" that will allow Episode to meeting DG's 720x512 spec with the click of a checkbox. It'll "automatically" add the 32 lines at the top of an MPEG2 encode.
If the tests go well it could be ready today or at least by Tuesday. Fingers crossed.
Matt Steeves
on Jan 18, 2008 at 5:20:44 pm
I actually was just speaking to a tech at DG about having the capability to do this in Episode...and they have no clue as to how. If you are able to pull this off, you will be a God among Men!
He also mentioned a new system they are implementing soon (about a month or a few) that will automate most of these processes on the back end so that we dont have to worry about most of the compression settings.
Please keep us updated
Mac Pro 3.0 Quad
Kona LHe
Panasonic HPX-2000
Craig Seeman
on Jan 18, 2008 at 5:37:33 pm
I'm a beta tester for Episode.
Have a look over here at the other end of the COW.
http://forums.creativecow.net/viewforum/232
What I'm testing is not yet available but will be ASAP if it passes DG certification.
I did one test that passed and I testing another spot to make absolutely sure it's ok.
Craig Seeman
Episode can meet DGFastchannel specs with patch
on Jan 18, 2008 at 8:09:28 pm
I tested Telestream/Flip4Mac Episode DG Fastchannel Patch with both 720x480 and 720x486 source and both passed. With 720x486 source one must crop the top 6 lines with the Resize Filter. In both cases the resultant encode is 720x512.
Telestream has given me the green light to distribute.
If you would like the patch post your email and I'll send it with instructions to install.
matt steeves
Re: Episode can meet DGFastchannel specs with patch
on Jan 19, 2008 at 1:17:22 am
blueflamez@aol.com ... Thanks!!!
Mac Pro 3.0 Quad
Kona LHe
Panasonic HPX-2000
Kevin Bradley
on Jan 24, 2008 at 11:20:14 pm
Craig
Can this patch be used with Episode 4.2 or 4.3?
Christian McIlwain
on Jan 28, 2008 at 4:01:02 pm
Craig,
Please send me the patch.
christian@fourthrulefilms.com
I've purchased Episode and my results with DG have been very inconsistent, to say the least. Thanks for your help!
Craig Seeman
on Jan 28, 2008 at 5:35:08 pm
Sent.
I have some settings I can cook for folks too. I tested with both 720x480 DV and 720x486 10 bit Uncompressed sources and they both passed DG certification (with the 720x512 patch).
Troy Ross
on Apr 2, 2008 at 11:24:22 pm
Hi Craig, I would also like to get a copy of this patch if possible. If you could email this, I would greatly appreciate it.
Thx,
-Troy
troys.r.us@gmail.com
e. eric johnson iii
on Feb 2, 2008 at 4:02:28 am
hi craig,
can you please forward the patch to me as well?
thank you,
eric
eric@lillmonster.net
and
splicerack@gmail.com
e. eric johnson iii
LILL MONSTER MOTION PICTURES
principal, producer-director-camera
now in post production - START 2 FINISH: What It Really Takes to Race A Bike
Craig Seeman
on Feb 2, 2008 at 4:24:56 am
On its way.
e. eric johnson iii
on Feb 2, 2008 at 4:30:13 am
thank you, thank you!!!
i think i sent you a request via the episode forum as well. please disregard!
and thank you again!
-eric
e. eric johnson iii
Chris Tomberlin
on Mar 6, 2008 at 3:37:17 pm
I've used Episode in the past for DG encodes with no problems, but now it is failing. Can you also send me the patch ASAP? Is it included with 4.4.2 by any chance?
Thank you!
Chris Tomberlin
email:
outpostpictures(at)mac.com
Chris Tomberlin
Editor/Compositor/Owner
OutPost Pictures
Craig Seeman
on Mar 6, 2008 at 5:11:48 pm
Patch is now part of 4.4.2. It's the add empty VBI space radio button in MPEG-2 Profile.
Wade Leoni
on Aug 9, 2011 at 1:45:31 pm
Could you email me the files at wleoni75@hotmail.com?
