Pixellated transitions
Kwesi Johnson
on Jan 8, 2008 at 3:54:43 pm
I'm exporting a FCP file to MPEG2 through compressor. I use fastest encode, (one pass), but hen I watch it on the DVD, the fades are all pixelly. What gives and how can I fix it?
Daniel Low
Re: Pixellated transitions
on Jan 8, 2008 at 4:29:04 pm
Simple, use the High quality preset, only use 'fast' for 'drafts' and testing.
Kwesi Johnson
on Jan 8, 2008 at 7:49:39 pm
I have heard that doing a 2 pass compression adds artifacting, though
Daniel Low
on Jan 9, 2008 at 10:16:31 am
I'd be very interested to know where you heard that.
Did you try it?
Did it introduce artefacting?
Please share your experiences with the forum.
jusigirl
on Jan 24, 2008 at 5:15:49 pm
there are several posts in the cow that discuss the inferiority of compressor's VBR. I've been using compressor for 2 years and abandoned VBR's in the first month after hours of troubleshooting the pixelation i was getting and then finally reading about it here.
i just tried it again with the bit rates set to the defaults of average - 6.2 and max 7.7 and took a screen grab of the pixelated transition. not sure if/how I can post that here tho... i can email it if you like.
In any case, compressor is a piece of crap in my opinion and we're looking into buying episode. it's by far the best encoder i've tested.
experience is tough teacher
she gives the test first
and the lesson afterwards
