Sorenson Squeeze-> Flash Video: Audio out of sync
Jim Gunn
on Dec 28, 2007 at 2:30:47 am
I am trying to encode some 720 x 480 frame size DV AVI videos to 320 x 240 Flash video using Sorenson Squeeze 4.5 either with the CBR or VBR settings and the On2 VP6 codec. The video have a bit rate of 768 Kbps. In the final Flash video (.flv) the audio goes out of sync about half way through the approx 30 sec. clips The video looks beautiful with the On2 VP6 codec but the audio is screwed up. Any ideas?
mike velte
Re: Sorenson Squeeze-> Flash Video: Audio out of sync
on Dec 28, 2007 at 1:56:25 pm
This is known problem if you choose the "Embedded Video" option for Play Options in the Player Options settings. Stick with "Linked FLV Video" option.
Jim Gunn
on Dec 30, 2007 at 8:21:35 am
It does the same with the linked video option. Sorenson just can't seem to handle keeping the audio on On2 VP6 codec Flash video clips in sync. Adobe's Flash Video Encoder CS3 worked just fine though. Shame about Sorenson, it does a few things so well but it also lacks the ability to add watermarks to encoded videos, another big failure as far as I am concerned.
Jordi J Recort
on Jun 4, 2008 at 10:13:40 am
I'm having the same problem with the same config but on Mac.
Squeeze 4.5 + VP6... and I'm trying to compress DV files on Quicktime
Have you finally found te solution?
Jordi J. Recort
Composer & Editor
