Settings for Mpeg-4 in HD?
Per W. R
on Dec 3, 2007 at 12:00:32 am
Hi! I will play a Mpeg-4 file in 1920x1080 25 fps on a PixelMagic Mediabox HD. What is the best settings for the compression to get a good result?
The master file is 1440x1080 Apple Pro Res 422!
/Per
Danny2007
Re: Settings for Mpeg-4 in HD?
on Dec 3, 2007 at 11:15:47 am
How do you plan on using the Pixelmagic box, i.e. delivering to it over a network, or via an attached hard drive etc..
Per W. R
on Dec 3, 2007 at 12:06:05 pm
Hi! Just delivering from the built in HD to a flat screen via HDMI or analog component.
/Per
Danny2007
on Dec 3, 2007 at 1:13:28 pm
AFAIK the box will only handle upto 1280x720 with MPEG-4. If you want 1920x1080 you'll have to use MPEG-2 at around 28Mb/s. Obviously the box will upscale 720p to 1080p if you want it to.
Per W. R
on Dec 8, 2007 at 11:05:02 pm
Thanks, Danny! If I use Mpeg-2, does it need to have the audio muxed or can it take separate files?
/Per
